1. Remove any loose plasterOkay so..
1.clean up the wall.
2.put water around and on the wall.
3.wait for how long?
4.mix up browning and then apply. OR should I use One Coat Plaster?
5.wait for how long?
6.apply another coat.
7.finish with multi finish.
2. Give the wall a good soak
3. Mix hardwall(not browning)
4. Give another soak
5. Wait a minute for water to dry
6. Fill out with hardwall and use a straight edge to bring out flush
7. Wait till it is set(will be a couple hours probably)
8. Scrape patch back a couple mm to allow finish.coat
9. Mix finish (approx quarter bag)
10. Give a coat of finnish and allow to set, take extra care around edges
11. Repeat 9&10
12. Soak around edges and trowel around so patch is flush
13. Once finish is firm give the patch a soak and trowel flat
14. Once finish is hard soak once again and trowel again. Make sure there is no lip around the edge and you should be complete
Dean.
