Plastering over paint
4 Jan 2009
True North
Just wondering whats the best thing to do when needing a skim over a semi painted wall. I've removed all old paper and there are some patches of paint left on.
I was going to rub all the loose off then give a few good coats of pva before skimming with multi finish. I dont want to dot and dab over it.
What are my options & whats the name of the stuff with grit in you can paste on to give a key as i might need some in the future for some painted ceilings elsewhere in the house? View media item 28876 View media item 28875 View media item 28874 [/img]
the names of the grit bonding agents are
bond it, blue grit or wickes bonding agent but if your buying one of these anyway use it on those painted walls
ok i'll have a look for them and compare prices. The stuff id been told about was like a green paste with grit in someone said its around £50 a tub.
In my opinion do not go for prices. Try best paints so that it remains for a longer time. Money once invested should pay back for at least as much time as possible. Try to search for good painters too.
but he wassnt asking about paint and what paint is the cheapest he was asking what bonding agent to use to give a good key for plaster to stick 2???? :?
i've been using feb bluegrit a lot of late, impressed with it and as Steve says, the cheapest of the 3 by some distance.
yes score the wall for key then use bond it or if u are on a budget give it a coat of neat pva with a roller,let it dry overnight then give it a second coat jus before skimming
