Hi all
I have recently had a room plastered and am not happy with the results. I was quoted a two coat plaster finish and am interested to know how you can tell if one coat or two coats were used? I think the plaster has been put on very thin as scrim joints are visible in places and some of the plasterboard edges can be seen where the plaster is a slightly different shade. Where the plaster has been applied up to the edge of the door frame it looks to be about 1mm thick.
The reasons I am not happy is that you can see the scrim joints and or pattern in places and there are lots of trowel marks and indents. I will need to do a lot of sanding and filling. Also there are places where the bead edging doesn't line up around windows etc... and the plasterer has plastered infront of the bead to line the edge up. All the walls were plasterboard first so there should be no reason for the walls and edging not to line up.
I would be really grateful for any advice that you could give me as to how to tell if a job has been plastered with one or two coats and should I expect a better finish?
Thank you for your time.
