Plastic paint scraper
22 Feb 2022
Does anyone have any recommendations for a plastic paint scraper?
Looking for something that will remove some paint from glass where I've painted a door and some has spilled over the edges- also need to remove some paint from the letter box and key hole surround but don't want to scratch any of it
Thanks!
A good-quality metal paint-scraper or blade works ok on glass without scratching it.
Tool Station sell a scraper with a razor blade that would be okay for the glass. Other outlets are available.
A plastic paint scraper will not remove hardened paint.
Not expensive but I would recommend the following Olfa product
I use it frequently but would add that if you use in on the letter plate, you are likely to scratch the finish.
Alternatively use a mild paint stripper and cut some timber at 45 degrees to use as a scraper. The edge will become blunt over time though.
