I'm about to embark on my first plumbing project; replacing a radiator and associated pipe work to the lounge. I've read some of the previous posts and i'm pretty sure I know what I'm doing but would like a few things confirming:
Is plastic pipe acceptable on a sealed central heating system, as long as pipe is barrier pipe?
Is inhibitor ok to use in systems with plastics pipes?
Are all pushfit fittings and pipe compatible? i.e. don't have to be same brand pipe and fitting.
Can I use plastic pushfit isolation valves on my existing copper pipes to connect the new plastics pipes. The existing isolation valves are leaking so i want to change them.
I reckon the answer to all them is yes but I'd like someone more knowledgable than myself to confirm!
