40mm Push fit and compression waste pipes and 40mm solvent weld waste pipes are not actually the same diameter on the outside of the pipe. So be sure you pick up the right ones!
so can you use push fit joints on normal 40mm waste pipe ?
I have a normal 40mm waste pipe and i want to use push fit joints and push fit pipes. Can i use a straight push fit coupling to join the normal pipe to the new push fit pipes together?
