Hi I have a ravenheat boiler. LS100. About 7 or 8 years old.
Anyway for a while it has had the overheat / lockout issue when the central heating is on. This seems to be the classic of put your hand on the flow pipe and after a few minutes it gets very very hot and the boiler shuts down. The pump was changed not that long ago.
I've had a couple of bits of advice (mainly get a new boiler) but that the problem itself is caused by the heat exchanger.
The system has been flushed and seemed pretty much ok.
So I disconnected the pipes to the heat exchanger (you can do this without entering the combustion chamber) and it is very easy to blow through them.
I did this for both heat exchangers, the main one and the dhw one. The water that came out of them was clean.
What I don't know is if something changes when the heat is on? What I mean is, is blowing through them when cold and there appearing to be no blockages a valid test? I have also blown through the pipes serving them and they seem fine using the blow test.
Thanks very much,
Jamie
Thanks very much,
Jamie
