I've just moved into a new home and have discovered a problem with my shower fittings - see photo...
Water is dribbling very slowly (one drip per minute) from the top fitting and very quickly ( 2 pints per hour) from the front and back of the right hand side nut. I borrowed a large spanner but couldn't turn the nut at all in either direction. The leak from the nut has got progressively worse over the last month so I've had to turn the cold water supply off to stop it. There's no name on the fitting either.
My question is this - can I get away with squirting some silicone around it to buy some time? Money's very tight at the moment so I can't afford a plumber for a couple of months.
Also, does this look like a quick fix with a bit of ptfe for the plumber or does it look like I have to buy a new shower as well?
Any advice very gratefully received,
A Damsel in Distress
