    Dismiss Notice
Please help stop the drip from my flue pipe
Discussion in 'Plumbing and Central Heating' started by dalston, 19 May 2013.
  1. dalston
    dalston
    21 Mar 2011
    47
    Thanks Received:
    London
    Country:
    The flue pipe for my Valiant boiler isn't entirely airtight and is dripping from the joints. A few droplets dripping now and then wouldn't be a massive problem had it not been for the fact that they contain some kind of sulphur or rust and which stains the grout in my bathroom.
    All help would be appreciated.
    As always, my images appear upside down in this forum. No idea why.... well, I hope you can still work out my problem...
    Correct image: http://farm8.staticflickr.com/7303/8755036582_2fced11201_c.jpg
  2. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,424
    Hertfordshire & London
    Country:
    It is dangerous. And a crap installation.
    Turn it off immediately and get a professional in ASAP.
    Doubt it will be cheap though. New flue, new boxing with hatches.
  3. hazetimesfive
    hazetimesfive
    1 Dec 2011
    2,986
    Thanks Received:
    325
    Surrey
    Country:
    either silicone the joints externally (may look rough)
    or get a gas installer to take it apart and silicone it.
  4. dalston
    dalston
    21 Mar 2011
    47
    Thanks Received:
    London
    Country:
    Thanks guys.
    First answer; why would it be so dangerous? It's just the steam from the boiler going trough the pipe. A miniscule amount of that steam again dripping out.
    Second answer; would I use silicone on the outside? Or do I have to take it apart, then silicone the relevant parts and then screw it back together while the silicone is still wet? Seems like I would risk creating a massive mess.
    Actually, I was hoping there was some kind of tape, rubber seal or similar material I could use.
  5. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,424
    Country:
    The flue is not adequately supported.
    The flue is not protected from environment it is not designed to be in.
    It is leaking liquid. If it is leaking liquid, it is also going to be leaking products of combustion.
    Turn it off and get a professional to look at it ASAP.
  6. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
    "JUST STEAM" is products of combustion or, more commonly, fumes - they can kill!
    If the steam is coming out you have serious problems, as said earlier, don't use it until it's been sorted.
    There does't appear to be any support on the flue either.
  7. Tom1981
    Tom1981
    29 Nov 2011
    353
    Thanks Received:
    43
    Norfolk
    Country:
    That's a awful install, it needs serious attention from a Gas Safe Engineer!!!
  8. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,424
    Country:
    Funny how yet another OP vanishes as soon as they don't get he reply they wanted?
  9. Sponsored Links
  10. smeghead12
    smeghead12
    29 Oct 2012
    13
    Thanks Received:
    2
    Yorkshire
    Country:
    hi , i am a gas fitter for a large company and work on about 4 to 8 boilers a day , firstly what a terrible place 4 a flue , i have come across flues like this before in bathrooms and checked with gas safe and is legal which is amazing just hope the boiler casing never gets a live wire touching it from inside or outside the boiler thus making the flue live while u have a shower , secondly if i come across a flue leaking as yours is i will turn off the boiler and hand out a id certificate & cap the gas to the boiler , i think it may be possible that the rust marks may be condensation on the flue near the shower making the flue rust but looks more like the flue leaking - the flue seal going or gone or not right from the install within the flue , do not mastic , ask a gas engineer to check it out , you do not mastic leaking flues that is terrible advice , tony
  11. hazetimesfive
    hazetimesfive
    1 Dec 2011
    2,986
    Thanks Received:
    325
    Surrey
    Country:
    If u say so
  12. Corgigrouch
    Corgigrouch
    13 Dec 2007
    4,009
    Thanks Received:
    511
    Country:
    Smeghead is right.... Products of combustion leaking into the property is Immediately dangerous and globbing loads of silicone about is not an adequate repair.
    Smeg head, if the boiler is earthed and correctly bonded then it will be safe even if there is a dead short to the boiler casing... That is the purpose of the earth wire..
  13. dalston
    dalston
    21 Mar 2011
    47
    Thanks Received:
    London
    Country:
    Huh?
    No I'm still here. Contacting pro's as we speak.
  14. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,424
    Country:
    Top Man. .. believe it or not, it is your safety that concerns us.
  15. neiltheplumber
    neiltheplumber
    13 Feb 2011
    665
    Thanks Received:
    107
    Birmingham
    Country:
    That's rather funny! :rolleyes:
    • Thanks Thanks x 1
  16. Corgigrouch
    Corgigrouch
    13 Dec 2007
    4,009
    Thanks Received:
    511
    Country:
    That's rather scary.....
Loading...
Share This Page
