- Joined
- 24 Jul 2015
- Messages
- 95
- Reaction score
- 1
- Country
I will be refurbing an internal bathroom. Currently there is an axial low voltage fan on wall in zone 1 in corner of bath/shower area with about 9 ft of ducting to outside.
The flat has many outside walls and condensation / mould growth has been a problem in lounge and bedrooms.
The easiest thing would be to replace the axial fan using the ducting already there. Maybe with a centrifugal fan?
I was thinking if the fan can be on constant and ramp up when it detects humdity it might help. If it can also boost when the light switch is pulled, then even better.
If the fan can be almost silent when on low constant that would also be good.
I thought that Nuaire Cyfan might be the answer but I looked at the install instructions and it seem that it should be mounted on an outside wall...however my bathroom is internal.
ANy suggestions on a fan I can get fitted using the original ducting? Many thanks.
