    Dismiss Notice
Please recommend a CCTV camera
Discussion in 'Alarms, CCTV & Telephones' started by tilerman, 3 May 2021.
  1. tilerman
    tilerman
    4 Mar 2007
    146
    Thanks Received:
    6
    London
    Country:
    Apologies if this is a repeat thread. I am experiencing regular fly tipping outside my garage. I need a CCTV camera that is discreet and must be battery powered as there is no mains available. Also with a memory card and capable of night vision. The battery needs to last ideally around 6 hour's with a memory card being abled to record about the same time. The idea is to put the camera on the dashboard of my van to hopefully get images of the culprit's responsible for dumping huge quantities of waste on my property. Thank you in advance.
  2. pcaouolte
    pcaouolte
    15 Nov 2012
    308
    Thanks Received:
    77
    Lincolnshire
    Country:
    Use a dash cam wired to the van's battery? They can detect movement and only record when something is happening.
    • Like Like x 1
  3. Sponsored Links
  4. secureiam
    secureiam
    20 Jun 2014
    5,347
    Thanks Received:
    667
    Lancashire
    Country:
    Wildlife cams aren’t discrete but good images, the local council might help, contact your local councillor?
  5. Sally2000
    Sally2000
    6 Feb 2013
    445
    Thanks Received:
    43
    London
    Country:
    If it's private land, the Council won't be interested. It's not their problem and they would rather the dumping was on someone else's land than in the street where they will have to clear it.
  6. Sponsored Links
Loading...
Share This Page
