Pleasr Help - cracks in loft room wall
30 Sep 2012
West Midlands
Hi all
please can someone help me,
my son has just bought a house which was built in 1900, and has two loft rooms as standard,
the house was survey and all was mentioned was the electrics may need updating, small damp issue and house suffered from subsidence in the past but this has now stopped.
but since picking the key, and we have gone into the loft room and noticed two vertical cracks, starting from the centre of the wall and going down, behind the skirting board,
i dont think its come all the way down as the room below has no crack but then again the wall is wallpapered.
please look at the pics and advice me if it is a serious thing or just a plastering job?
also can i make an issue with the bank who done the survey?
View media item 50746 View media item 50747 View media item 50748
thankyou for your help.
i have ripped some of the wallpaer off so you can see crack, i have pulled out some of the loose pieces from the wall, it looks like plasterboard but behind there you can see bricks and its looks as the brick is cracked.
Old houses get cracks all the time. Just fill it with pollyfilla and forget about it.
You don't say where these cracks are in context of the rest of the house ... inside partition, party wall, external wall?
hi, thankyou all for your responses.
i dont know how to describe what type of wall it is,
so i have uploaded a picture of the room, the red arrow points to where the cracks are,
the other side of that wall is the neighbours house, it a semi detached.
its the View media item 50760
thanks again.
I don't think it's a problem really, just fill them and decorate.
As has previously been said, old houses get cracks and 99% of the time it is nothing to worry about.
thanks for the response,
i seriousally hope it is just a crack, but the size of them worries me a little,
googling this, it says it can be subsidence or something similar
or something simple like a plasterboard but you can see a crack in the brick behind the board.
so still unsure
any further help would be appreciated.
It's not the place where a subsidence crack is likely to occur. You have not shown a chimney on that wall, is there one, or was there one?
Otherwise it may just be a plaster crack.
If it was subsidence there would be a crack on the neighbours side too.
