I have just purchased a property and im having the whole plumbing and central heating done. The property has 2 bathrooms one on the ground floor and one on the first. It also has an onsuite in the loft. A problem i had in the property i moved from was that, when the sink taps were on downstairs you would get poor flow in the bathroom upstairs etc. Furthermore the plumbing was, i believe so badly botched that in the bathroom with the cold water supply (15mm pipe) branched of to the sink, then a branch came of this to the shower, with a branch coming of this to the toilet. This would cause the the shower to die if you turned the tap on or flushed the toilet.
I asked the plumber if this could be overcome in the new property by running a 22mm pipe for the cold supply to the loft and branching 15mm pipes directly of this for the shower and toilet etc. One of the plumbers said that this could be done, however the other said only 15mm could be taken to the loft for the cold water. The mains water pressure for the property is good. At this point it should be evident i am a complete noob to plumbing. I would be grateful if somebody could tell how the pipe branching should occur in this property, and if theres any way i can prevent the problems i have described from occurring in the new property. thanks
