I'm a spark who needs a bit of advice from a plumber (why don't plumbers have a nickname?).
1) I have to install an air admittance valve (durgo) in my bathroom (building control insisted on it!). Some books have informed me that the height of the valve should be directly above the w.c. pan outlet and others have said it must be above 'flood level' whatever that means. Anybody throw some light on this?
2) How do you install a draincock on 15mm pipe? The draincock obviously must tee into the pipe but how is this done? Is there a 15mm tee compession fitting with draincock fitted? Or do you solder it in. I have purchased a draincock but how it fits into the existing 15mm pipe is beyond me.
thanks in advance
Scott
thanks in advance
Scott
