I've bought a new house and I'm upgrading the open vented CH system. I'm adding a mid-position valve so the existing CH gas boiler can supply the existing indirect hot water cylinder too - the cylinder is currently heated by an AGA cooker which I'm removing.
But I can't find a drain cock anywhere obvious. The DIY guides say "the drain cock will be found in the return pipe near the boiler". Not on this system!
The boiler and HW cylinder are both upstairs - the 28mm feed/return pipes from the boiler split into two pairs of 22mm pipes, one pair serving the upstairs rads and one pair the downstairs rads. To do my job, I don't need to drain the downstairs rads (in fact would prefer not to), so any drain point below the boiler would be fine.
So before I start taking the whole house apart looking for the mythical drain cock, are there any places I should look first - where do plumbers tend to put them? Before the other trades cover them up again
If I fail to find a drain cock, can I use a clamp-on screw-in valve - the kind used to install a washing machine to an existing pipe - to create one? Or would I just create a flood? I wonder if these are available in 22mm size, I've only seen 15mm. Once drained I could fit a proper draincock to replace the clamp-on valve. If so where on the system should I put this?
Thanks for some advice.
Phil.
Phil.
