I am installing a cloakroom suite and unfortinately will have to use a saniflo. The problem is that the saniflo will be on the other side of the room from the basin. The only downhill route to the saniflo is aroung the wall and behind the toilet, this will not look so good.
Could the waste go down under the floor boards horizontally to the saniflo and then up a bit to connect to the unit? In theory the water should flow but would there be any long term problems ie blockages etc...
Its just over a meter across the room.
