pointing perished in dpc brick work
2 Oct 2004
The mortar in the first layer of bricks of dpc has perished /eroded.
What mix is needed to repoint and method of replacement ?
It is the first layer only at outside ground level.
TIA
1 part OPC to 3 parts sand. No Fairy Liquid :rolleyes: Rake out 25mm depth and repoint, joint profile to match existing.
thoroughly wet the area first. use a brush to wet it as this will remove the dust and wet the area to be pointed at the same time.
