POLISH PLUG
16 May 2011
Worcestershire
Hi new to forum, so this has probably been asked beford,
The wife has just brought a Waffle Iron (maker) x2 they have a two pin plug I want to put a UK plug on it.It has an Earth lead and a blue lead and a browny/greyish lead .Question is which is the live of these last two.Im guessing the browney.greyish lead is
They are 1900W CE approved.
Thanks Gordon
Probably is.
Why has it got a 2-pin plug if the flex has an earth core?
Is the appliance double insulated?
Thanks for responces Two pin plug with a female hole for earth the extension socket that we were given has two female holes for live and nutral with a male pin to connect for earth.
Fitting a new plug is simple enough but when you come up against this type of plug which I havent come acros myself you start to doupt your yourself.
Hence looking for advice.
Thanks again Gordon.
Try a firm called powerconnections they make an adaptor that the europlug fits into to enable it to be used with a BS1363 socket outlet.
I use Schuko adaptors - as shown above - for the Braun kettle and coffee maker I bought from Germany.
Wikipedia said:
When inserted into the socket, the Schuko plug covers the socket cavity (1) and establishes protective-earth connection through the earth clips (2) before the live and neutral pins (3) establish contact, thereby preventing users from touching connected pins. A pair of non-conductive guiding notches (4) on the left and right side provides extra stability, enabling the safe use of large and heavy plugs (e.g. with built-in transformers or timers).
if you get the adaptors, make sure they:
1: have an earth, seen quite a few travel adaptors that don't
and
2: can take the load you need, again seen a few with a limited capacity, more designed for laptops/phone chargers etc.
