Polished concrete floor
5 Oct 2005
I would like to create a mirror polished concrete floor in a contemporary kitchen - it's done a lot in warehouse conversions. How's the best way to do this as builder is putting screed down next week. I have underfloor heating too. I don't mind if the floor has small cracks as this adds to the look. It's 47m2 minus the units' area. I presume a power float is used just before the surface is rubbed up? Does it take long?
Is someone doing this for you or do you intend to DIY?
You will find the floor will be grinded using a power float but putting sanding/grinding pads on it, normally carbon based, generally a wet sand is done to prevent concrete burns and help keep the pads lubricated, but it can be done dry.
The floor will need to be left to cure for about 4-6 weeks, depending on drying conditions, it may also need treating with a concrete hardening solution to toughen it up, before grinding is done.
It can be quite a messy job, but before you lay your floor, decide what type of look you want, as this can be helped by a good choice of aggregates in the mix, which can add sparkle, colour and character to the floor.
