its not that big, cos i would off placed a piece of plasterboard behind it and dunt it that way, it is ruffly about 55mm x 40mm
and i don't even think it is that to be honest
Why would a plasterer use polyfilla as a subcoat? If it's about 20-40mm wide, stick a bit of pva in it, and skim anyway (if you're really enthusiastic you could stick a bit of scrim over it). Ant bigger then use a proper subcoat plaster.
cos it is only a small hole and it is not really big enough to go get a full bag of it, and as i work in a college i don't really need to use bonding and there is none at the college as most of the students have finished
You may be right Richard, of course, but I've taught many a student whose level of spelling and grammar is quite comparable. So, for me at least, the jury is still out.
