Polypipe vs copper for CH plumbing
Ah yes well in that case, Ive see soldered joints leak given enough time with a poorly made joint. So well have to put access panels everywhere for those too. Ahh **** it lets just surface fix everything and then we wont need the access panels.
Ah Dan I can see whats happened here. Nobcon only works in bungalows with concrete floors as hes never heard of cabling pipes through joists.
You don't want push fit plastic under the floor as the joints will lea.
Unless you fit access boxes.
Where did you say "some"?
I wasn't specific.
If I'd known you were going to start gobbing off I might have been.
But yes some may leak and indeed all of them may leak depending on how they are fitted.
