    Dismiss Notice
Pond pumps, is this feasible.
Discussion in 'Electrics UK' started by prefab, 10 May 2020.
  1. prefab
    prefab
    14 Nov 2013
    54
    Thanks Received:
    Kent
    Country:
    Hi All,
    Just wondering if it would be possible to wire 2 pond water pumps into a 2 gang outdoor switch, screwfix code 69431. Power would be from a 13amp plug from the garage to a weather proof junction box in which a float switch is wired. The power line currently leads from the junction box to a Blagden switchbox which needs replacing. At the moment if anything happens to drastically reduce the water level the pumps will switch off.
    Any help would be appreciated.
  2. john4703
    john4703
    29 Sep 2009
    489
    Thanks Received:
    28
    Glasgow
    Country:
    Why do you need a switch outside? I used to have a fish pond and everything was 12 volt fed from a transformer inside the house. Can you put all the switches inside the garage?
    To give a proper reply you need to show a lot more of what you plan to do.
  3. Sponsored Links
  4. chivers67
    chivers67
    18 Nov 2008
    1,404
    Thanks Received:
    172
    Surrey
    Country:
    Is the wiring/cable to the pumps protected by anything for mechanical damage? What are they run in exactly?
    • Thanks Thanks x 1
  5. prefab
    prefab
    14 Nov 2013
    54
    Thanks Received:
    Kent
    Country:
    Thanks for the replies.
    John 4703,
    Need switches near pond for convenience. Pumps are main voltage not 12v.
    Chivers 67
    Outside cable to junction box is armoured cable. junction box next to switches.
    Any more help would be helpful.
    • Like Like x 2
  6. Sponsored Links
  7. Mottie
    Mottie
    27 Feb 2017
    17,508
    Thanks Received:
    1,810
    Essexshire
    Country:
    My dad used to use a central heating pump.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
