Poor pressure from thermostatic mixer
16 Feb 2015
Lancashire
Hi everyone
I have just replaced the shower mixer in one of our bathrooms with this
http://www.victorianplumbing.co.uk/...ic-Bar-Valve-Bottom-Outlet-Chrome-VBS001.aspx
The hot water pressure out of tap is excellent - just had a new 40kw combi installed delivering 16lpm. Pressure out of the mixer is okay but not what it could be.
Is it because the mixer is cheap? We have 2 more to fit and am wondering about trying more expensive mixers if this is cheap? If not, has anyone any idea if it can be adjusted?
Matt
10 Mar 2007
Poole, Dorset
What size and type of shower head?
By pressure, do you mean flow? Have you measured it?
In any case, a combination boiler with 3 bathrooms is a total fail.
19 Oct 2008
Lancashire
Hi
It's a 10cm diameter shower head, not sure of the make. Fairly cheap though, about £15 for the head.
There are only two of us in the house so combi boiler is fine - the boiler easily supports two showers at the same time, but my question was more about whether anyone had an opinion on whether a cheap thermostatic mixer can affect the pressure?
20 Mar 2009
Potters Bar
Where did you measure 16l/m?
Where is this shower head in relation to that? What can your boiler output: temp/litres per minute?
Are you evaluating shower output whilst additional draw offs are being used?
15 Aug 2010
Livingston
as already advised its flow rate you are talking about, you need to measure it pressure means nothing
19 Oct 2008
Lancashire
OK, so kitchen sink flow rate is 10.5l/m @ about 60 degrees C. Shower flow rate is 6.6l/m @ same temperature.
21 Nov 2015
Might be your hoses especially if it came with a cheap head.
Cheap ones tend to be really narrow bore which is restrictive. You can get wide bore ones to replace.
20 Mar 2009
Potters Bar
And where is shower outlet in relation to kitchen sink? Height in approx meters?
19 Oct 2008
Lancashire
Thanks everyone for input - did some more testing and...
I think that it could be the shower head.. Measuring the rates has led me to determine:
10l/m directly from mixer.
10l/m from end of hose (without head on).
6.6l/m from shower head.
Cheap shower head! Can anyone recommend a shower head that will output 10l/m? It seems that none of them specify a rating for the flow rate?
