This is similar to the problem Benson had.
I have installed a complete new close coupled toilet, the one in the Wicks cat. but it does not seem to flush very well.
It fills up properly and when you push the lever it seems to work properly,apart from the fact that it does not seem to empty the cistern enough, ie a fair amount of water at the bottom of the cistern after flush. (100mm)
I have changed the handle crank position, and also plugged the over flow to get more water in than the 6 litres but this does not seem to have helped - any suggestions?
PS I know some one may say its the diaphram but this is also new - unless it has moved or is kinked?
