I have one those pop up waste plugs on the bath where you turn the overflow to open the plug....connected by a cable - no idea how it is supposed to work/where to start....
Don't know if it ever worked since i lived here - all I can remember is it being stuck down once and not being able to empty the bath....fixed bath panel etc meant I didn't have access to it so have been using a standard plug for years...
Currently fiddling under the bath and thought if it is an easy fix now would be the time to do it....
Not tested with water (drains are disconnected at the moment) but turning the knob moves the plug up a tiny bit ...and back down again...
What kind of things on these need adjusting/fixing and how do I do it?
