    Dismiss Notice
Porch just over 3M Sq, is there margin in permitted development?
Discussion in 'Building Regulations and Planning Permission' started by Saarek, 12 Mar 2021.
  1. Saarek
    Saarek
    12 Mar 2021
    6
    Thanks Received:
    Country:
    Looking to do a porch, permitted development says 3M Squared is fine but above that we will need to do planning.
    The dimensions of our planned build is 3.18M Squared. Is it likely that someone from the council will come and measure up after we build, or is it likely that no one will notice?
    Don't really want to go through the hassle and cost of planning if we can avoid it, especially for such a small difference.
  2. Sponsored Links
  3. Notch7
    Notch7
    15 Sep 2017
    24,312
    Thanks Received:
    1,735
    S. Uplands
    Country:
    Nobody will ever check unless a complaint is put in and the planners have to come out and check.
    If they did, you would be asked to make a planning application.....they have no choice because whoever complained would be able to point to the rules.
    However in the real world the chances of getting a complaint are very very low, so unless you have a neighbour from hell, just get on with it
    • Thanks Thanks x 2
  4. Saarek
    Saarek
    12 Mar 2021
    6
    Thanks Received:
    Country:
    My wife thought we should perhaps apply for a lawful development certificate, that way if any neighbour decided to look online they'd just see that we have permission.
    I wanted to just take the risk and the builders seemed happy enough. Planning is a nightmare around here, a neighbour down then road tried to have a 4M Square porch and the planning department refused as it "would not be within keeping of the street", in the end they had to a 3M Square, which is what got me worried. It shouldn't look obviously out as it's so close.
  5. Nakajo
    Nakajo
    5 Dec 2014
    2,074
    Thanks Received:
    188
    Berkshire
    Country:
    Well it's not pd, so it's not lawful, so don't apply.
  6. Saarek
    Saarek
    12 Mar 2021
    6
    Thanks Received:
    Country:
    What I meant was apply as a 3M Sq for the Certificate. Unless somewhere ever measures they'd never know the difference and the neighbour would just see an approved development.
  7. Notch7
    Notch7
    15 Sep 2017
    24,312
    Thanks Received:
    1,735
    S. Uplands
    Country:
    And don't forget, less than 3 metres high
  8. Saarek
    Saarek
    12 Mar 2021
    6
    Thanks Received:
    Country:
    Yes, well within that limit! :)
  9. ^woody^
    ^woody^
    3 Sep 2006
    33,335
    Thanks Received:
    4,518
    West Mids
    Country:
    I measure all extensions etc as part of any building survey, and check them against any approved plans or PD in effect at the time of the build.
    • Like Like x 1
  10. Sponsored Links
  11. Saarek
    Saarek
    12 Mar 2021
    6
    Thanks Received:
    Country:
    Would a building survey be required? I assumed one would not be needed for a porch?
  12. ^woody^
    ^woody^
    3 Sep 2006
    33,335
    Thanks Received:
    4,518
    West Mids
    Country:
    The person I quoted stated thay no-one ever checks. Clearly someone does. :rolleyes:
    No, you may not need a building survey, that tends to be asked for from buyers.
  13. tony1851
    tony1851
    23 Feb 2012
    10,262
    Thanks Received:
    1,549
    Manchester
    Country:
    "Spoke" and "wheels" comes to mind.:whistle:
    • Like Like x 1
  14. mrrusty
    mrrusty
    1 May 2018
    642
    Thanks Received:
    132
    Country:
    Are porch areas calculated on internal floor area like outbuildings? Is this porch over 3m2 internally or externally?
  15. clifford1
    clifford1
    9 Aug 2010
    232
    Thanks Received:
    13
    Pembrokeshire
    Country:
    3 metres square is 9 square metres.
  16. mrrusty
    mrrusty
    1 May 2018
    642
    Thanks Received:
    132
    Country:
    True. My bad - wasn't thinking...
  17. frutbunn
    frutbunn
    22 Jun 2020
    837
    Thanks Received:
    155
    Country:
    It will only get measured if there's a complaint and planning enforcement get involved, even its marginally over its highly unlikely it will be taken any further, certainly at the last two authorities this never happened, even if planning enforcement wanted to it had to go up to legal to be sanctioned, the reply for a minor infringement would inevitably be "not in the public interest", so the case was closed.
Loading...
Share This Page
