Hi All,
I thought i would post this up as info for anyone with one of the above units before you end up with a destroyed wood floor like i have.
Check out the amount of moisture your unit can remove from the air in 24 hours, most have a drain valve like mine however the maths can be scary.
I woke up yesterday morning to a flood in my bedroom as the shut off failed to activate when the water tank filled up to max and deposited the rest onto my bedroom floor. As the tank is only 1.5 litres i didn't think the unit would need emptying out that often which such a small tank and the inaccessibility of the drain valve which is about 25mm from the floor.
After lifting the 40KG unit into the bath to drain it yesterday i thought it would be fine and reinstalled it.
This morning i ended up with an even deeper flood (about 15mm deep) after clearing it all up i decided to do some more research.
The unit can extract upto 45 litres of water a day in humid conditions.
The internal water tank is 1.5 litres, of which you can only drain about 400ml at a time.
Then comes the annoying bit:
45 litres a day equates to 1.875 Litres per hour (MAX) which explains why i got flooded a couple of times.
What level of ****** would fit a water reciever of 1.5 litres to a product that in it's highest ouput overflows in about 50 minutes. This unit typically runs through the night, as i normally go to bed about 1 and get up about 10 that equates to:
1, a big flood
2, 16.8 litres of water
This just makes no sense to me whatsoever!
Anyway, armed with this info i called them up and they just said "OH, when it's really humid you just have to empty it more often" I responded "How would you feel being told to empty the unit every 50 minutes when you use it to cool a bedroom? having paid £800 for it" This is a unit from a very large company and not sold by the sheds.
I have sorted the problem by raising the unit by about the width of a PC (an old shed i had lying around) and went to get some pipe to drain it externally, punched a 14mm hole through the wall and connected it to the drain on the unit. I decided to test it while i'm awake, prevention being better than cure and all that and it's liquid output is quite shocking.
I have measured that it is roughly outputting 750ml per hour which means the tank would be full in 2 hours or less. Since 8PM tonight i now have a bucket half full, at least it will overflow into the garden and not my floor.
I hate products designed by a designer without any consideration whatsoever for an end user or trades that have to work on them once out in the wild.
Just check what your unit can do! it may save you a flood or two
Jon.
1, a big flood
Jon.
