Portable air conditioning units.
27 Feb 2017
Essexshire
Anyone got one? Any good/how quiet are they nowdays?
We had one about 15 years ago in the villa and it was a toss up at night between sweating to death or being kept awake by the noise. We soon changed it for a proper set up with the outside units etc. Any recommendations, its only for the bedroom? May have missed the boat though as everywhere seems sold out of the good ones. My main consideration above anything else is the noise.
Have you thought about or tried one of the oscilating tower fans. They are pretty quiet and we never had a problem sleeping with them.
Yeah, we have a Dyson tower fan but our bedroom is in full sun from midday and it’s just getting too hot lately. Tried shutting the blinds and the curtains but it still heats up.
I brought a portable one about 4 years ago. Yes its too noisy to sleep with but I have it in the bedroom and use it to pre cool the room which it does very well so that its much easier to get to sleep.
I made a board that slots in place of an open window, it has a hole to attach the ducting and then also keep the bedroom door shut.
I use water cooled fan , no ac but blows cooler air at you and is fairly quiet. Timer is set for 3-4 hours as don’t need it running all night .
I’ve a wall mounted fan pointed at bed , basic but useful when hot
Ventilation can presumably play a role in cooling at night ? I’ve a small opening on the windows in summer
Oscillating tower fans we've found are really good, but it's all dependent on a through draft. Ideally you want it drawing in air from the outside, not just blowing warm air around. You can also try freezing as many water bottles as you can fit in your freezer, and hanging them in front of the fan. They will melt, but might provide enough cool air until you go to sleep.
I think these A/C units are quire pricey when you compare them to a cheap fridge. It would be interesting to see how a fridge works as an A/C if you drill a hole in in and have some pipe coming out
If the room is really hot before I put it on open all the windows in other bedroom and the air con unit has a just fan option which is quite powerful so I use that and push out a lot of the hot air at night.
Fans slowly loose they advantage as the temperature climbs to 36°C and make the situation worse after that point.
So today living room at 24°C with the AC running, and from the amount of condensate I have poured down the drain, also a lot drier.
The flat is built into the side of the hill we live on in Wales, so that has remained at 21°C my bedroom however, normally cooler than the living room is at 28°C. So AC or not does depend on windows and their direction, our patio doors do not help.
So the AC uses 755 watts, and will just about keep the 24 x 18 room with 2 windows and a patio door at a liveable temperature, I would not call 24°C cool. But without it looking at 30°C.
The AC exhaust goes up the chimney, so no windows open with a pipe out of it, and the door propped slightly for the cats.
Main downside, today emptied the gallon cider bottle 4 times with the condensate it has collected. If we needed it for more than 3 weeks a year, may look at an installed unit. But don't need it for most of the year.
This shows the use, just before 8 am AC turned on, to start with running on battery, by 9:30 am the solar was powering it, but was 11:30 am before the battery was fully recharged, so then the domestic hot water started using solar it was 12 an hour before noon (we are in British summer-time) before that too was satisfied, from than exporting at this moment 3.5 kW being exported, my array is 6 kW with a 5 kW inverter.
So about on the 5 kW limit. It is costing me, loss of revenue at 12p/kWh so 9p an hour, so may not be efficient, but at 9p an hour, I am willing to pay that. If it keeps being so hot, then out with the SDS drill and a hole in the wall for the condensate.
We find if we wait until the day has warmed up, it does not really cool the room enough, so we have to switch on early.
The use of chimney means no windows open, but if we go out, has to be switched off, due to condensate, but can turn on with smart socket adaptor before returning home.
Now I think year 4 or 5, when we got it, under £100 likely before Brexit and came from Lidi. If it failed we would replace it.
