We were told last night (by an emergency engineer) we have a gas leak in our internal gas pipework, and our gas meter has been turned off. We actually called the engineer as the cooker gas smelt of paraffin and we thought something was wrong, but he said that was just caused by an interaction with varnish, which we were having done). Discovery of the gas leak was coincidental.
The pipe from the meter (which is under the stairs) goes underground to a kitchen in an extension (where all gas appliances are located) and exits the ground in a boiler cupboard in the kitchen (and from there is attached to kitchen wall to service cooker).
Please could you help me with the following questions:
As we have not smelt gas in the kitchen, is this a strong indicator the leak must be in the underground run?
Is there technology to sheath the internals of the underground pipe to avoid ripping up the floor? If so, is it very common/expensive?
An option is to run make the existing pipe redundant and run a new one along the external side wall to the extension. The only issue I have read about is the possibility of the copper being stolen! Could we use a less expensive material externally to minimise that risk, or otherwise secure it?
