Postcrete for brick laying?
10 Jul 2024
What can you add to postcrete to stop it setting so quickly, sand? plasticiser? Washing up liquid?, I only have 7 bricks to relay...thanks
Do you mean cement rather than postcrete?
If only doing 7 bricks you should be ok without any additive.
Mortar plasticiser is used to keep the mortar usable for longer
4 parts sand, 1 part cement, splash of plasticiser
You'll probably only need 1 bucket of mix
Postcrete makes concrete not mortar, it sets too fast, and perhaps worse also contains stones that will make it impossible (although I bet some have) to use as mortar.
You can easily and cheaply get premixed mortar (even from Amazon!!!).
Spend the £12 on the real thing....
No I mean post'crete', I know it's concrete but the only difference is it's got stones in and sets quicker so if I add more sand, I've taken all the stones out with a fine garden and washing up liquid, will this work?
Please, PLEASE video you attempting to lay bricks with postcrete.
That's right up there with underwater hair dryer. (y)
Postcrete is designed for fast setting and poor strength. It does not meet the normal standards of concrete. You will see on the label that the manufacturers warn against trying to use it as a building material.
Do you feel you have a need for fast setting cement? Or are you attracted by the idea of buying a small amount of premixed product?
Postcrete is ridiculously fast setting. I've used it for its intended purpose with fence posts, you only need to hold the post for a couple of minutes before it grips it. Seive all the stones out, add a bit of plasticiser but it will still set before you finish mixing it.
You can hold it when I switch it on then, I only asked a question haha
