Postergeist in the Central Heating System??
here I go again but every thing these days is a regular fault with Ideal. Thats why I don't fit them any more. (sorry I don't want to start another manufacturer debate again, just my personal experience!)
wishwash said:
will ideal do anything about this as its now 2 years old - its been noisy for about 18 months and getting louder!!
thanks
not unless you paid for an extended warrantee they wont do jack but they will tell what YOU need to do
gas4you said:
wishwash said:
my boiler is definitely an icos - but i dont think the problem is boiler related - tho im only repeating what my boiler maintenance guy said
Check pipe work from large tank in loft to cylinder. What size tank in loft? Are you running tank dry in loft because it is too small for your hot water use or perhaps your cold mains pressure is too low to fill it up quick enough. If running out loft tank then air will enter pipe work each time.
the tank in the loft is pretty large - the banging noise happens even when i havent used any hot water that day - will ask the engineer to check this
thanks
corgiman said:
thanks
i think ill get one of those british gas warranties and pretend this is the first time there has been a problem - :lol:
thanks
If you only have 3 copper pipes out of the bottom, flow, return & gas in the middle then I think you have been conned if you have your facts straight. Unfortunately Ideal are very reluctant to help anybody outside of warranty and at present will not take on any chargeable calls due to the number of boilers going wrong under warranty! The only way I get things sorted is to give my Ideal area sales manager grief on moral grounds as although I don't fit them any more I am still party to a contract with them!
If your rads are working ok I still suggest you check your DHW circuits and cylinder as previously said, or call your 'combi installer@ back!
another thought. Take out the Ideal extended warranty, wait the 28 days before you can call them, then call them in with the fault!
they also wont be interested if it hasnt been flushed properly
and the icos still aint a combi
Quite right corgiman, I've had probs with them even though I always powerflush everything properly. Ideal engineer on site confirmed water sample good, but guess what, Ideal report found minute particles and disagreed with their engineer. One of the many reasons they lost my business!
Can I havea month to think about it! Yes they are all the same but I personally do not like the Aluminium ones. When you service an ideal Icos or Isar look at all the rough edges on the visible heat exchanger parts. If the internals are the same then god help us!!
dont matter if the system is clean
our experiance is that "powerflush" some times needs doing again
