potterson boiler
7 Oct 2008
Cheshire
my potterson boiler fault. when you run hot water it gets hot asnormal,but when u turn of the water pipes rattle and gurgle as if air trapped ,sometimes the boiler then locks out , its a potterson combi 80, hope fully somebody can help .thanks :lol:
Remove two screws to take off front panel....look on pcb....red light is probably staying on when you turn off the hot tap. If so new flowswitch assembly required.
for what its costing i will just replace and go from there. after read ing potterson fault finder in manual it also says problem switch .cheers.
