Afternoon all,
I have a Potterton Combi Plus A boiler, almost 2 years old, which worked perfectly until a few weeks ago.
It then locked out on Error Code E133, shown in the book as Interuption Of Gas Supply or Flame Failure.
I turned the adjustment screw for the Gas/Air half a turn anti clockwise and it seemed to cure the problem for a while, but it has now started again.
This morning it showed an Error Code of E168. I have searched my documentation but can find no reference to Code 168.
After attempting the reset knob a couple of times it then showed Error Code E133 again. It showed this a couple of times so I turned the Gas/ Air adjustment switch a touch more anti clockwise. All seems to be working satisfactory for the moment.
Has anyone any info on Error Code E168 please ?
I have just noticed a section on the Gas/Air adjustment screw saying:
NOTE: To assist the boiler to light prior to final setting, use a suitable hexagon key to wind out the Gas/Air adjustment screw until it is flush with the valve body, then turn the screw 4 full turns clockwise.
Perhaps I should try this if I get the error codes again ?.
All useful suggestions will be greatly received
Many thanks
Many thanks
