hi.is this ready for a clean up around the burners?? my instinct says it is or is it ready to be replaced?? im on a budget ..any suggestions if it does??
flamingos often burn away the combustion chamber insulation board retainers allowing the board to fall onto the burner. I may swap mine out this summer after 32 years of service as someone gave me an ideal classic!
I think it want's checking by an RGI ASAP before (assuming it is open flue) you and your family are overcome by CO. Let him decide when in front of it if it is worth servicing.
hi. had the boiler looked at today.it was a piece of lining that surrounds the combustion chamber that had dropped off and was sat upon the burner thus causing the smell!!. it was held on dot and dab style with a piece of fire cement??? some more fire cement has cured it hopefully??
