The immersion tank is upstairs, see photos
It's an indirect Hot Water Cylinder.
Not an immersion tank.
Thanks, it's all new to meIt's an indirect Hot Water Cylinder.
Yeah, I've never had an install look like this. I'd still have bought t4 house, but I'd have got the engineer in before moving in for sure.So, maybe best get someone in, to whom, it's old hat!
Someone better than whoever threw plastic pushfit fittings in everywhere!
It's another lash up I've seen tonight on here.
No wonder people have Heating problems!
Still... You get what's paid for I suppose.
I'm afraid after your photo, I have to agree with...Added photo to original post.
Thanks for helping
Together with the lash up of pipework, you also have potentially dangerous electrical connections...Looks a lash up with the plastic fittings so, who knows what could be wrong with it! Needs looking at by someone who knows what they're looking for (and not).
Thanks to everyone who has posted. Sincerely appreciate it.If you can afford it.
Get someone in to sort it properly else you'll be firefighting forevermore.
Thanks, I think the boiler looks quite aged so would prefer to upgrade. I'd also like a better thermostat and more functionality between the two so I can see fault codes, programmable temperature settings etc.Ok, 2 bathrooms - if you intend to use simultaneously then a combi is generally out of the question as it would struggle to cope with 2 draw offs at the same time.
You could keep the existing setup and maybe just bring it up to a standard with an S-plan. You could upgrade the cylinder if needed, boiler upgrade might not be required yet. An unvented cylinder could be an investment, but thy require annual servicing too.
Just engage with an engineer or 2, work out a feel for them and go from there. If they try and sell you a combi, show them the door. Some are accredited installers with manufacturers meaning they can offer longer warranties. Boilers aren’t what they used to be, some are better than others, some are just pure garbage. Stay away from Biasi, Ferroli and maybe a few others.
I have ADHD and stuff like this just overwhelms the heck out of me. I've tried to educate myself on most things being female and on my own, but it isn't easy.
The property is a 3 bedroom loft converted bungalow. 1 bathroom upstairs, 1 downstairs.
What would be the best course of replacement? What would you recommend in terms of best boiler type, siting,etc.
It'll be helpful to approach the engineers with a plan of sorts.
Thanks,
@Madrab is based in East Renfrewshire
