The central heating is working but the hot water is warm. Any ideas out there.
header tank empty?
Is your boiler a combi or do you have a cylinder?
New to gas work are we.from the boiler you should know its impossible for it to be combi
Its very likely to be the motorised valves or feint chance of the cylinder stat
Gas valve faulty?
header tank empty?
An empty header tank will stop the flow of water from the cylinder.
header tank empty?
Eh? Im vexed by that comment
It could be gravity hot water circulation.
If the header tank (cold water storage tank) is empty then there could be no flow of water, hot, warm or cold from the outlet of the cylinder.
The flow form the cylinder is dependant on there being water in the header tank.
