potterton kingfisher no hot water
A
angelf
potterton kingfisher no hot water. Any ideas why this is? Thought it might be motorised valve or pump. It has solar panels if thats any help?
If you have no hot water then obviously not!!
Which model of kingfisher do you have?
A mark 11?
You have no water because:
You pilot light is out or
Your F@E Tank is empty or
Your boiler has broken down or
Your pump has failed or
You have a Zone Valve failure or
Your programmer is faulty or
You have a blockage in the system.
Ill go on if you want?
Hope this helps.
Paul
