Potterton Netaheat 10-16 Mk2F query.
28 Aug 2007
Boiler seems to operate normally then switches off sporadically after about 20 minutes.
If I give the Electronic Ignition Generator a tap it starts up normally again. Is it likely that replacing this part will solve the problem.
Replies appreciated.
sounds like you may need a pcb. get a co detector for this boiler while you are at it. and get it serviced. and plan on replacing it.
