Potterton Netaheat 10-16 that keeps blowing 1 amp fuse
B.O.B DOLE said:
well chaps my money is on the pump at 2-1 fav
Can I have a weeks wages on that too? The pump is powered from the call for heat, and should be fed from the main 3A fuse, not the 1A PCB fuse.
Oh, and can I have 20p each way on the fan? :wink:
turn on make aps see if gas valve opens and ignition sequence starts
corgi gazza how would you do this would i use a peice of rubber hose on aps and blow
Don't blow much or you'll break it! Blow AT the hose end and it should switch.
