I've no idea? What should I look for? There are 2 bleed heads on pipes near the tank and I've bled those.
Is that an air-bleed point just behind the Honeywell valve?
when you bleed the air points on the cylinder, does the water run freely ? it is possible that when the pump was changed that some crap has been drawn from the F&E tank and has blocked the cold feed
I think you have got rid of the air so now to find out why the boiler is cutting out , is the pump wiring connected to the boiler on the correct connections ?
But I haven't bled anything yet? How would I have got rid of the air?
I hear a tiny hiss and then water starts to come out so I shut them off
Sounds like you have.
