Bit of a problem - xmas eve as always
On CH my Potty Puma 80E only runs for about 30 seconds before switching off. A couple of minutes later it fires up again... for 30 seconds or so. The closest 2 or 3 rads to the boiler get hot, lukewarm for the next couple then cold for the other 2 furthest away.
Suspecting the diverter valve was a bit sticky / partially opening I gave it a tactical tap with a hammer - a voila..... heating stays on
Until.... the heating goes off for any length of time or the DHW is used... then back to the start until the tactical adjustment is made as above
Any thoughts as to whether:
a. this is likely just to be the wax head gone 'weak' (i.e. do they tend to either just work or not, or can they go weak?)
b. the valve itself is gummed up and could be stripped and cleaned
c. the valve needs replacing entirely
d. would it be worth draining down and chucking some X400 (or the like) in the system - would this clean any rubbish off the valve??
Can't find anywhere open this am for parts otherwise I'd chuck a new wax head on it to see if it helps. But I could pick up some X400 at B&Q if it might help!
Thanks for any advice... and Happy Christmas!
Cheers
Graham
Cheers
Graham
