    Dismiss Notice
Potterton Suprema 80L
Discussion in 'Plumbing and Central Heating' started by username pain, 2 Nov 2015.
  1. username pain
    username pain
    2 Nov 2015
    4
    Thanks Received:
    Country:
    Hi folks :cool:
    I'm sorry if I'm in the wrong forum for this, but I have a problem with my manky boiler.
    Its been happening for a while, then it got better but now its extracting the urine! o_O
    The problem I'm having with this boiler is that the flame will go out but the boiler is still running as if it was working. But with no flame we have no heating and no hot water but a boiler that is constantly running. It will carry on running even when the timer had supposed to of gone off turning the boiler off. Well its supposed to do.
    I have been told its an electrical fault but I'm rubbish with DIY hence me joining this forum :D
    Anyway, am I looking at a replacement boiler or could it possibly be fixed by an electrician?
    Thank you :)
  2. Sponsored Links
  3. 75pete
    75pete
    9 Apr 2008
    661
    Thanks Received:
    60
    London
    Country:
    Does it fire up then flame out then fire up etc etc
  4. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,087
    Thanks Received:
    1,091
    Norfolk
    Country:
    Might be a fault with the boiler, or an external fault, but as you've stated that, I would suggest a professional.
  5. username pain
    username pain
    2 Nov 2015
    4
    Thanks Received:
    Country:
    Most of the time now, it wont fire up but the boiler will be running as if it should be fired and working fine. Today I checked it after I had to reset it and turn down the heating thermostat. Once reset and the thermostat turned it, it fired up but within 3-4 minutes the flame was out but the boiler was still running :(
  6. Sponsored Links
  7. 75pete
    75pete
    9 Apr 2008
    661
    Thanks Received:
    60
    London
    Country:
    Got to say, it does sound like a elec fault, best you get your gas safe service engineer in.
  8. username pain
    username pain
    2 Nov 2015
    4
    Thanks Received:
    Country:
    It came on at 9am this morning for the hot water. I turned the thermostat up and got the heating on. After around 5 minutes there was a funny little noise (can't explain what it was like) and I looked at the boiler and the flame was out :(
    I'm thinking electrical fault and maybe overheating and flame going out as a safety precaution.
  9. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,087
    Thanks Received:
    1,091
    Norfolk
    Country:
    I'm thinking, you need to reach for your wallet and get a pro in. Winter is coming.:D
  10. username pain
    username pain
    2 Nov 2015
    4
    Thanks Received:
    Country:
    I had a plumber come out yesterday evening and he thinks its the pump not working properly and the reason why the boiler is cutting out is because its getting too hot and tripping out. Which is what I thought before.
    So he should be back later today to replace the pump :D
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
