- Joined
- 11 Jan 2004
- Messages
- 60
- Reaction score
- 0
- Country
I had the fairly common problem that my Potterton Suprima would "lock out" and flash it's red LED once per second. Going on the advice given by several in this forum, I replaced the PCB and wiring with the "upgrade kit" 5111603 PCB which is supposedly more reliable.
However immediately, I now have a different, but similar problem. The boiler will light up fine and start heating up the radiators as normal, after the water is hot, it will stop firing (flashing green) a few times while the house starts to heat up. However, after an hour or so, it will change and will flash the RED LED about once every 3-4 seconds or so.
According to the fault-finding guide supplied with the new PCB, a RED LED flashing every 5 (I make it more like 3) seconds means "check thermostat". The thermostat seems to be OK. It has a resistance of about 500kohms when warm and drops if I hold it between my fingers, so I refitted it with thermal paste. Same results at PCB end so wiring OK.
Does anybody have any ideas what might be causing this problem? Is it likely that my brand new PCB is faulty?! Or perhaps could the thermistor/thermostat still be faulty at high temp.
I don't get what causes the boiler to flash the LED at this rate (technically speaking). Is it that the resistor goes outside the normal range, or could something else be causing it?
I'm reluctant to call in Potterton who will charge me £225 and may not even fix the problem.
Nick...
Nick...
