That boiler (Suprima 80) is still a decent bit of kit- decent efficiency, very few moving parts to fail. The weak link is the PCB- prone to failure (your symptoms do NOT indicate PCB fail) and replacements are expensive and still prone to failure. Rather like your old Volvo (and my old Citroen), if the black box packs up it tends to go beyond economic repair.
For now, this fault should be a straightforward fix for a competent electrician with the right test gear. Treat it as a wake-up call- nothing lasts forever, time to start contemplating (and budgeting for) a replacement. Advantage of planned replacement- you can take your time, consider any other changes you might want to make, schedule it for the summer when you will get much more competitive prices for boiler swaps. And don't be pressured into a combi unless you really want one- they don't suit all circumstances.
EDIT Since the dhw is pumped that rules out the pump as being the failure point. Or drops the probability massively anyway. You should have 2 2 port valves (unless the original installer decided no-one would want heating without hot water being on)- one probably near the cylinder controlling dhw, another one somewhere controlling the heating. If the heating one has a manual override lever, use it- the rads should get to full temperature (not just warm) while the cylinder is being heated
