Hi
I have a strange fault with my boiler and I can't figure out what is going on.
I have a Potterton Suprima 80 HE approx 6 years old and I haven't had any major issue until now.
Two days ago it stopped working, the indicator lights were all off. Previously when this boiler had the occasional blip and lockout it would indicate an issue with a red flashing light which I could clear by resetting the boiler. But this latest issue could only be cleared by switching the fused switch for the boiler off and waiting an hour and switching it on again. The boiler would then fire up, green indicator lights come on as normal and provide heating as normal for anything between 1 hour to 8 hours before it completely shutting down again.
I've been through this cycle about 5 times so far.
I worked through the following checks:
After reading around it seems that it is not uncommon for the PCBs to go faulty, so I removed and inspected the PCB and it looked looked like new, no black / scorch marks as people seem to often report, solder joints clean and solid.
So I came to the conclusion that one of the PCB components have become faulty.
However while the boiler was in shutdown mode and before I went to switch off the fused switch I disconnected one of the connector blocks on the PCB and the boiler switched on with green indicator lights. It was the connector block which has live neutral and earth wires only and leads to the gas valve.
While the boiler did switch on, it was unable to switch on the burner which I presume is because I disconnected the power/control to the gas valve.
It made me wonder if it is after all a fault on the PCB or is the gas valve faulty?
The PCB is a Honeywell code 5110550.07 manufactured May/09
If it is the PCB I would consider replacing it myself as it looks very easy.
Anything else I would call someone out.
Any advice would be much appreciated!
- Checked that the pump is working and sounded like normal
- Checked the expansion tank and made sure nothing was blocking the flow
- Checked that the valve near the hot water tank is working
- Bled the radiators and fairly sure we don't have an airlock
- All radiators would warm up as normal and hot water is ok
- Flue isn't obstructed
- Listened for the fan in the boiler and I could hear that working
- Timer and room thermostat set correctly and seem to be in good working order
