Hello all
I have one of these boilers and it has been working fine till tonight.
The orange light shows constantly indicating (as the manual puts it) "Mains "ON" - No external call for heat".
If I turn up the room thermostat setting to very high the boiler should fire up/ignite and the light should turn green indicating full correct function.
I have turned up the heat setting for both water and radiators, tried other things but nothing works. The boiler refuses to move off the constant orange light. It does not fire up.
I have switched off the entire system and turned on again, following the laid down procedure for restart, only to be presented with the constant orange light again.
Any suggestions anyone what the problem may be and how to fix it?
All suggestions welcome and thank you, in advance, for your help.
