pouring concrete pad stones
24 Jan 2011
Surrey
I will be pouring a number of concrete pad stones in situ
These pad stones will be according to the building inspectors spec, however, what is the best way to do it, make the pad stones at perfect height so they will take the RSJ and are at the perfect height, or do I make them about 10mm lower and pack the RSJ with a dry mixture of cement, so it will sit at the perfect height (also knowing that concrete shrinks when drying therefore achieving the perfect height is difficult)
Your help/comments are appreciated
You put your shuttering at the bearing height required, and level the concrete off
Why are you going through this palaver, instead of just building the pads in solid blues, cut lintels or buying some padstones for a few quid - less than the time and cost of shuttering?
By pouring the pad, there will be a better weight distribution over the existing bricks,
:eek:
Really?
Better load distribution than a fully bedded padstone, and so much better to warrant the messing about?
Perhaps not so better if you don't get all the air out though, or if the bearing face shears
I like your motivational thinking, and would like to subscribe to your newsletter
I wonder if there are any implications of a padstone bearing on only half the width of a block rather than spread over the full width?
