E
EddieM
Today at around 10:00am we had a brief powercut, this is not at all uncommon round here, so didn't think anything of it. Power was off for around 2 perhaps 3 minutes, and most of the house rebooted ok. The broadband router was dead as a dodo though.
So I checked the fuse in the power flylead, that was OK
I checked the flylead was outputting 230v AC (having remembered to carefully check what range the MM was set to
) OK
I then removed the phono power plug to the router from the transformer, no voltage.
I disconnected the transformer from the mains, and let it rest a while (aren't I kind)
After about 20 mins or so, I reconnected the transformer to the mains flylead, checked the output voltage on the transformer 6.15v which is correct.
Plugged the transformer lead back into the router, nothing still dead.
Checked the voltage from the transformer again 0v dead.
Tried this a few times, each time I plugged the transformer into the router it would go from 6.15v output to 0v.
So question is what would cause that? apart from the blindly obvious that the transformers shot.
And yes you guessed it I opened up the transformer in my usual optimistic way, hoping for a neon sign pointing to the culprit. No such luck as usual.
I've remedied the situation, with a new transformer, but was curious to know which bit of the transformer had most likely given up the ghost?
I've put this in electrics as I think it will get a more relevant audience that hardware. TIA.
