Power flush or Magna Clean for blocked DHW heat exchanger
2 Feb 2015
London
Hi
Our boiler is cycling on and off during demand for hot water and turns out the heat exchanger in the Alpha boiler is clogged up. The boiler engineer is going to replace the heat exchanger and said a power flush should help avoid this happening again.
When we use the radiators, they heat up really well and there are no cold spots. Considering that and the potential risk of a power flush upsetting the delicate world order and unearthing any leaks(!), I was wondering if it made sense to install a Magna clean filter when the new heat exchanger is fixed; and keep cleaning the filter regularly till it starts collecting less gunk?
How much would it cost to get a mangna clean filter fitted in the London area?
There is little point asking for prices - we can't see the job.
A Magnaclean won't catch every bit of muck first pass anyway, so if there is sludge in the system it will still collect in the boiler. Best to get rid of it properly.
Generally it takes a very little dirt to block a plate heat exchanger, perhaps just 2-4 cu cm of dirt.
If it has taken several years for yours to block then it is likely to take several years again.
Fitting a mag filter is probably a good idea but they don't collect as much dirt as we would like or expect.
I had to clean a plate again after just three years in spite of the mag filter.
Although power flushing is certainly good for a dirty system it never clears all the dirt but is hardly justified on a lightly dirty system like yours.
I clean plate heat exchangers as this is more cost effective and at my charges it is rarely economic to do anything else at all although a mag filter gives people a nice feeling.
Tony
Thanks for your input, I was probably aiming for that nice feeling if it does not cost the earth ;)
