It will dwindle away. You can double the time between cleans as long as the dirt keeps reducing. Eventually once a year will do. Sentinel make a keep-in chemical now for use with filters, X900, it keeps the particles in suspension so they can be trapped, it is not drained out.
So let me put it into my own words so I understand correctly, so you add the x900 and inhibitor and keep both of them in for a year?? and the x900 makes the gunk more likely to be trapped by the filter??
you keep them both in until you have some reason to drain them out. While it is circulating you continue to clean the filter regularly, but the frequency will reduce as the dirt declines. Instructions on the Sentinel website. There is another one that is supposed to slowly break down limescale.
you keep them both in until you have some reason to drain them out. Instructions on the Sentinel website. There is another one that is supposed to slowly break down limescale.
Listen Dan,
You and a few others on here like to take threads completely off topic with your sarcastic and unhelpful replies. With regards yourself, I'm guessing you changed over time as I see you have received > 6000 thanks. Don't be a grumpy old man... try and be that guy who got 6K thanks
